I have tried both the options - blocking the pop-up window and setting exception and also unblocking pop-up window. Why pop-up window does not open ?
I am unable to use pop-up window in Firefox in the last three versions. I have tried both the options - Block the pop-up window and set the exceptions and unblock the pop-up window altogather. Pop-up window does not open at all.
Do I need to change any settings in my laptop ? How and where do I change it ?
Please guide as I need to open IE or Crome to use pop-up window when a site requires that.
Thanks
被采纳的解决方案
Hi,
Usually a horizontal strip with Options on the right edge would appear on the top (below the location/address bar) when encountering a popup. If you have toolbars, or an Extension that adds extra security functionality you could try to Disable that in Tools (Alt + T) > Add-ons, and check.
You can also try the Reset Firefox feature via Help (Alt + H) > Troubleshooting Information.
(To revert to the previous profile you were using, close the new profile (i.e. exit Firefox), start Firefox and choose the Default User profile. While the Profile Manager is open, you can also delete the newly reset profile (the one containing random numbers), or the former profile, as the case may be). If the reset is okay, it would be a good idea to delete the old profile as otherwise it would be left intact with the previous data/cache until deleted.
Can you also please post a link??
定位到答案原位置 👍 1所有回复 (3)
选择的解决方案
Hi,
Hi dumdidadida,
I reset my Firefox browser and lo ! Everything works fine now and I also get the pop-ups whenever I need it. While resetting, Firefox also remembers all my previous passwords, history and bookmarks. Only thing, I had to reinstall the plugins / extensions. But it is all clean and neat now.
Thanks a lot dumdidadida. You saved me a lot of work.
Ashok
Did you notice a pop-up block icon on the right end of the location bar when a pop-up was blocked?
Did you try Safe mode to check if an extension was blocking the pop-up and did you make sure that your security software isn't blocking pop-ups?
It is also possible that you run into this pop-up maximum (the default value is 20).
